Hard To Find Information
farshot83
hello,
I have a 2000 GMC Jimmy 4x4 4 door SLE...
The front end sags lower by about 3 inches. I always have a 200 pound "grill guard" on the front and often in the winter. I would like to put "stronger" torsion bars in the front with bars that have a higher sring rate. I know there are about 5 different sets of bars available. Where can I find detailed information about these parts and possibly others online? The part numbers and diameters of the bars are as follows.
LH 15956501 26.63mm
RH 15956502
LH 15956503 27.94mm
RH 15956504
LH 15956505 29.36mm
RH 15956506
LH 15956509 30.69mm
RH 15956510
LH 15956511 32.51mm
RH 15956512
I hope this is enough information to atleast get the ball rolling.
I dont want a replacement. I want an upgrade. Something with a slightly higher rate to make up for the extra weight of a plow and in the sunny season a 200 pound "grill guard".
The parts guy can tell you whats on your truck, then you can pick out a bar with a higher rating. Or do what ChevyTech 77 says. You just might not be able to do it on the web.
Mark
    CaptainDad
    CaptainDad
  • Who's Online   1 Member, 0 Anonymous, 559 Guests (See full list)
