Alignment Specs Before\after 2" Level Kit
Hello,
Can anyone tell me how bad there alignment was after installing their leveling kit?
I just installed a 2" RC leveling kit on my 07 GMC 1500 CC. It handles horrible now. I had it aligned right after installing the kit,but all the shop said that was out was the toe? Does anyone know if it was toe, camber , or caster or all the specs that were out after the blocks were installed on their trucks? It just seems like I cannot keep it straight now? It looks like most are saying they had to adjust more than just toe?
Thanks
I would take it to another shop, and not go back to where you had it installed. There should be no issues with alignment after a leveling kit. I've had 2 different leveling kit installed on my truck, and never had issues with alignment.
Mine was out on toe only. I drove it for a few hundred miles before getting it aligned. It handled fine in spite of being out but the specs show it was way out.
Thanks.
I had it aligned at a local shop that does mostly alignments/ front end work. I put the blocks in myself. I can definitly tell a difference after the blocks were installed and alignment was done. It was a little better after the alignment but no where near factory. I have had other trucks with real lift kits, and a few with the torsion bars cranked and this is worse than any of them??? I was (am ) hoping the shop just tried to hurry the alignment and did not get set correct. It was not the usual guy doing the alignment. He said he will check it but if it is on I will be charged again
There going to charge you again if it's on??? Not very good customer service. F that. Take it to another shop and pay them to do it. Your probably going to have to pay either way. That or make that idiot ride in the truck with you and show him how off it is.
