Here we go! Got the new Bullet Liner bed liner installed today by G&W Truck Accessories in Oceanside, CA. They were a previous LineX dealer and switched over a few months ago. I am very pleased with the installation, look and feel. Over the rails rocks!
I'll post a periodic review to report how it is holding up.
Here are some pics:
I think it looks really good and the tailgate cap isn't that bad, Better then trying to fill all the holes under it. :P
what is the price compaired to rhino and line-x?
Does look good.
Well, they are comparing it to LineX Premium. That being said, it was about $200 less than LineX with the premium up-charge. As far as Rhino, they seemed to be all over the place with different charges for different levels of this and that.
E
I really want to try a Bullet liner too but the nearest dealer is in Albuquerque.....and I'm in Tucson. :D
That is the one draw back. They released late last year and are just making their way around. I happened to come across them because the dealer that did the Line-X on my last truck switched over to Bullet Liner at the end of last year.
E :P
