Remote Start Install
i have an 01 silverado would like to install remote start. how hard is it to do and which product work the best?
Installing can be a pain depending on vehicle, it worth paying someone to do it with remote start. Clifford, Viper or Compustar are all good brands, it all depends if you want it to be an alarm as well or just remote start or if you want smart fone capability which one you pick.
I vote Viper. I had one for 7 years, installed in 2 trucks and it always worked flawless. They aren't for the novice to install though... I'd really consider letting a competent installer do it.
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 850 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
