Gmt-900 New Speakers?
Recently I have been having issues with my factory driver's door speaker cutting in and out. I thought I noticed it a while back but it came back on, so I thought I was imagining it. Today it happened again and I was able to verify the speaker is not working sometimes.
Therefore I need to replace the factory non-Bose speakers in the doors of my reg cab Z-71. Crutchfield recommends a Kicker 6 1/2 inch 2 way for the front doors. They said they would go well with my factory receiver and would not need an amp to sound good. They told me they were the best speaker they carried if I was sticking with a stock receiver and just wanted to fix my speaker issue. They are going to run me about $70.
For only $25 more, I can add a 4 inch 2 way kicker for the rear pillar and they recommend the baffles for them. My only worry is going from a 4x6 factory to a 4 inch round speaker. Anyone else tried this with good results?
I can get 4 speakers, 2 baffles for the rear pillar, all instructions, brackets, wiring harnesses, etc shipped from Crutchfield for $102. Anyone know if this is a good idea and deal? When it comes to car audio I'm clueless. I know the front door speakers need to be fixed but I don't know if upgrading/changing the rear pillar to a 4 inch round would be a good idea or if I would even notice a difference good or bad. Any help is greatly appreciated.
My speakers did the same exact thing. I just replaced them with the kicker 6 1/2's and they sound ok with the stock deck. As for the rear speakers I have a crew so they were the same as the front. Most companies make 4x6 speakers that would be a better fit. If I were you I would not put 4" round speakers in the rear.
Steve
