Fs: Oem Nav From 07 Nbs Silverado
This unit has a broken cd player, but everything else works great. This came from my silverado with Bose system
PN: 15940103 - non DVD
This is a great unit for the fixer, I have seen the cd part on ebay for less then $100, but I am not that savy with electronics.
Price to move at $300 OBO plus shipping
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
