Silverado 4.8l To 6.0l Swap "build Thread"
So after searching the internet, talking to numerous people, and looking through a million forums, I was never able to find any sort of "build thread" outlining a 4.8 to 6.0 engine swap. So I decided to make one, and share my research with others looking to do this sort of thing.
So to begin, after doing more research and talking to more people than the world has to offer, I have made several findings and conclusions. Please note some of these pertain to my 2003 truck, not just any year.
- The 6.0 motor must be in the same year range (2003-2006) in order for the wiring harness and parts to be exactly swappable.
- NO extra parts are needed in order to perform this swap except for the 6.0 motor
- The proper motor for my truck is a 6.0L out of a 2003 Silverado 2500HD
- OPTIONAL parts that I purchased were the short harness, new plugs and wires, water pump, O2 sensors, knock sensors, and of course Mobil 1 Full Synthetic
- The flexplate must be swapped from the 4.8 in order for the 6.0 to fit the 4l60e transmission
- It is recommended that the computer be flashed to run the 6.0 motor, although the engine will run WITHOUT this flash, the ignition timing will be off however
Alright everyone, the time has come. My 6.0 crate motor from GM has arrived this afternoon. I have taken some (crappy) pictures just out of pure excitement. The install will begin Monday morning and is being done by Bohan's Automotive in Canyon Country, CA.
Also I would like to give a HUGE THANKS to Justin over at Black Bear Performance for all of his help and knowledge through this ordeal. He got my PCM done and shipped out the same day I got it! Talk about customer service!
Also a thanks to all the members here on GM-Trucks.com for all their help and knowledge!
Hope y'all are as excited as I am!!!! :uhoh::mad::D
The last set of pictures with the 4.8l....
  • Replies 62
Link to the photobucket? The photos are very small :lol: And my old eyes aren't able to see them very well.
Sorry for the llate reply guys!
Well I am in love. The motor runs perfect, fit perfectly, no problems. It is a HUGE difference from the 4.8. The power increase in unbelievable. Needless to say, I am one happy man. The motor can pull hills in 4th gear now, an important factor for me. I can cruise at 70mph at 1600 rpm.
The only negative... is that my trannys remaining life is EXTREMELY limited. I can feel it slipping under that 6.0. Yayy more money gone... :lol:
Anyone have any specific questions?
Glad to see it all finally come together..what was the final tally.... need to change your sig to include the install of a bad ass crate motor.. :)
Final tally... (assuming you mean the cash flow) was $5960. Including a few extras like water pump, knock sensors, O2 sensors, synthetic oil, sparkies...)
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 452 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
