2000 Chev, Transmission Problems
I found a chevy that is in mint condition. But he says the trans won't shift out of first and now it has to rev very high to move very slow. Anyone know what this could be? Just cooked clutch bands maybe? Thanks guys.
probably a cooked trans.rebuild is probably around 650 bucks around here in nj
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
