Towing With A Programmer
06_GMC
So I borrowed a superchips tuner from my brother and was wondering when I put in the tow tune should I also use the T/H button or will that cancel everything the tuner did? Im going to moab at the end of next week and would like to know. And hopefully this will help other that might have one of the other tuners.
Don't expect a miracle, but it will help. And yes, use the tow/haul mode if the trucks shifting alot. Also make sure you are using the appropriate octane fuel after the program when towing :lol:
Cool I will do that. I know how it tows without it tuned so i'll be curious if there is any difference, but I am not expecting much difference.
Those Superchips tuners are awesome!!! Your truck will tow better than a Diesel with that plugged in. I saw your trailer in another thread....looks nice. I bet your truck will get 15-16mpg towing it with the tuner. :lol:
^ Yeah I am so sure it will. hahaha I'll be curious to see the difference in our mileage between your camper and ours this weekend. A few thousand pounds can sure kill it quick.
I'm going to be pulling a PUP this June from IL to SD. I'm in the process of tuning with a Predator II using there 93 canned tune and tweaking a little. the Pop up's dry weight is only 1,800lbs. I don't foresee me using T/H to much with my bolt on's and tune, I'm making 30ft/lbs. more torque. I would think the Superchips program will have parameters for Tow Haul. I know Diablo does, and they are not so tow friendly and shock the drive train to much IMO.
i have a superchips handheld, but i have never tried the "heavy tow" or "light tow" tunes.
I usually am running the 93 tune and shift points and shifting from the tune make towing my atvs WAY better.
Well we are back from the weekend. I had the Tow tune on all the way there and had a gnarly headwind the whole time. The truck stayed in third and second most of the time and hated 4th. I got 8 MPG's the first tank and 6 MPG's the second. I uninstalled the tuner completely before we came home and gave it back to brisk and with the truck stock it felt like it towed better and could find the gear it needed a lot easier. Second gear was a rare occurrence this time and third was favored because of strong head winds coming home too, but the truck considered overdrive a lot more. My first tank home i got 6.5MPG's and the second I got 7.8 MPG's but the truck felt happier and sounded happier. And i really do love my magnaflow!!!
Surprised you got those results. I'd think the wind played a big factor in your trip. Both my trucks I felt the tune gave it an advantage... Also what octane was the tune for? If you didn't have the right octane for the tune, that could have been the cause of your results?
What kind of weight are you towing?
You've basically got two sets of parameters to work with: torque delivery (timing, fuel, etc) and shift patterns. It's possible to eek out a few extra ponies on the motor side (maybe 10 to 20 ft/lbs, but you don't want to take out torque management when towing). You then have shift points, and maybe "closed" vs "open" loop fuel delivery. I think that a good tuner could help in these areas, but it's a (relatively) small difference for a heavy load.
Example:
Empty truck: 6k lbs
Truck + trailer: ~13k lbs
Difference: +120%
Stock tuning: 310 ft/lb @ 2500 rpm
Custom: 320 ft/lb @ 2500 rpm
Difference: +3%
No amount of "tuning" will ever touch the weight difference. Where I could see (and do see) a potential benefit, is if you need/want different auto-shift points in the TCM. A custom tuner could take account of your actual weight/terrain, and adjust to "hold gear longer", "shift earlier", "don't use 4th below 60 mph", etc. Is it worth the cost just for towing? I doubt it... but the daily driving tuning could be improved in a more noticeable way.
Thanks for the replies. The camper probably weighs 7K loaded give or take a few hundred pounds. The head wind definitely played the biggest part in the whole deal. But like i said the programmer didn't offer me any impressive results. When the truck was tuned and just driving on a daily basis it made a little bit of a difference but again nothing worth the 300+ dollars for one. Im sure a Blackbear would be the only way to go and maybe even a cam and then have the truck tuned for a new cam. I'm not expecting diesel results but would like a little better performance and maybe mileage before going to a supercharger.
Yeah the SuperChips Tuner is junk. I noticed no difference towing my pop-up (~2500-3000lbs loaded) with or without it. The truck feels a little more "peppy" when empty with the performance tune but I see no other benefits milage or otherwise. It came with the truck when I bought it. I never would spend the money on one.
    • New to this forum.  Also looking to tune a 6L80 and trying to work out all the issues in my transmission swap.  I have a 6.2 diesel (1983) and have removed the TH-400 and about to put in a 6L80 with a TCM-2600 interface and don't have a clue what I doing after that.  Did you (Leatherneck/RAV3) get your slip resolved? I too hate to spend that kind of money on a tuner that hopefully I will not need too many times although from what steelerdude15 added about the HP Tuner being great for diagnostics would be a plus.  I am also from WNC but below you in Columbus.  Any helo would be greatly appreciated.
    • Sounds like a smart reasonable person with common sense. Bill O’Riley never said he was just a journalist, by the way.
    • It's like saying Bill O'Reilly is "just" a journalist.         Lauren Fix, widely known as "The Car Coach," is a prominent automotive journalist, television personality, and self-identified conservative. She is a frequent contributor to right-leaning networks and platforms, offering commentary that intersects the automotive industry, consumer economics, and conservative political perspectives. [1, 2, 3] Media and Commentary Network Contributions: Fix serves as the National Automotive Correspondent for Newsmax and is a frequent guest on Fox News and Fox Business. Video Platforms: She has contributed to PragerU, where she has hosted videos critiquing government mandates on vehicles. [1, 2, 3] Core Positions Anti-EV Mandates & Fuel Policies: Fix regularly critiques government subsidies and mandates for electric vehicles (EVs), framing them as impractical and burdensome to the average consumer. She advocates for consumer choice and supports traditional internal combustion engine vehicles. [1, 2, 3] Economic Analysis: Her commentary often emphasizes the impacts of fuel prices, inflation, and federal regulations on drivers. [1, 2, 3] Political Alignment: On her public channels, she actively supports deregulation, "drill baby drill" energy policies, and the removal of government restrictions on auto sales and manufacturing. [1, 2] For analysis from Lauren Fix on how consumer automotive choices can align with political leanings:
    • Wouldn't swapping out the original AFM/DFM parts for a complete Delete Kit be the best route to go if one could afford to go that route?
    • It comes with directions but yes, generally, it's the same.  Also, get you the dipstick stuff to install dipstick so you have one.
