That Jimmy on BaT did well. $22,250.
When it was $17k this morning I thought about jumping in, but with 5% buyers fee and 10% tax on the winning bid that's $26k.
Had it been a ZR2 2-door Blazer in the same condition I think I'd be driving to Idaho to pick it up. Working on mine has made realize how much I really do enjoy these. I'd like a *nice* one though if I'm going to keep one around for a while.
Working on 2022 3500HD gas. Truck was sold used to owner as having plow prep. It does but have the VYU RPO. It does have 220 amp alternator, 5600 front GVW, skid plates and I found while researching the vin "PV - UDU provisions rear camera prep, VYU provision snow plow". I have added a factory rear camera which works fine. What I need to know is what exactly may be missing to have snow plow prep as I will be installing a Fisher plow on this truck. Also will be adding upfitter switches. Thank you.
See...I think they are worse aside from Habanero. They are all some sort of super dark color like a super dark red or blue or teal. And the new 2027 Silverado EV colors that are coming, same thing. Dark, dark and dark.
Thanks for the suggestions guys. I have some Caig De-Oxit spray I used to clean the pins. I plan to try some food grade silicone plumbing grease applied to the seal with a Q-tip. I will report back with the results. Based on the feel of the connector not quite fully seating, I suspect lubricating the seal as suggested will fix it.
good to know Dave and thanks for sharing the video for others. I have since swapped over to oem led headlights so not concerned about drl's anymore. However one day when they stop working I'll probably just go back to the original halogen lights.
