Wtb - 07-11 Onyx Black Handles
Looking for a set of onyx black handles for my truck, please contact if you have a set for sale. Its for a reg cab so preferably a driver/passenger door, but may consider a complete set.
I have a set of four from my 2009 Onyx Black crew cab (replaced the handles with chrome ones a few months ago)
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
