Wanted
I'm looking for a white grill for my 2009 and also a white bumper insert. I have chrome pieces right now. Anyone who is looking to sell these let me know and also what you are wanting for them. Also, if you want to work out a trade for the chrome parts, I can do that too.
Thanks,
Josh
