Some Tread Help
JRLZ71
Hey everybody,
Haven't posted in a while... School has been kicking my arse here lately, and it has been extremely hard to get any free time. Anyway, I'm thinking about going up a size on tires. I've been looking at the 315-70-17 tires. I'm thinking about going with either bfg ko's, or Goodyear Duratracs. I'm keeping my stock wheels. Will they fit, or will I have to trim? Specs in my sig..
from what i've read, i think they will rub pretty bad and you will have to trim a good bit. a 315/70 is like a 35'' tire. some of the 6'' lifts rub on 35s without the proper back spacing. if your going to keep the stock wheels, id only go up to a 295/70 or if you get a 17x9 wheel, then id go with a 305/65 or a true 33x12.5. again i have no personal experience with mounting these tires, but ive done a lot of research on wheel/tire combinations as i have the exact same lift setup as you have waiting to be put on.
chad
Keep in mind, BFGs run small. I think I've made my mind up to steer away from a 315, anyway. I'm not even going to take a chance on it. Wish there was more of a selection for 305-70-17s
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 750 Guests (See full list)
