Transmission Shifting Hard
Went out this weekend with a new trailer. The trailer was realk close to 10K fully loaded. the truck is a 2006 2500HD with the 6.0liter and a 4L80E tranny. It towed beautifully the entire trip but after about 40 miles of the trip the tranny started shifting hard and it didn't matter what gear it was in. Under light acceleration the tranny didn't shift too bad but yoy could tell it was very firm. Onder a load and mid to heavy acceleration it would shift very hard almost felt like someone was rearending the trailer. What could this be? If this was the older TH400 I would say that this thing had a broken accumilator spring or a stuck mainline pressure valve. Any ideas?
Just to make sure, is the 2500 6.0L rated to tow 10,000 lbs? Did your truck also have a tranny temp guage? if so, what was the temp looking like? What does the fluid level look like and what does the fluid smell like?
If you are done towing, and if the truck is still acting like that, try disconnecting your positive & negative battery cables, touching them together, then reconnecting to battery, to reset the ECM. Then take her for a spin and see how she is shifting. If it is still shifting crappy, you may need to get her looked at.
Well I do have a turn of events that had happened on this tranny problem. I scanned the computer last night and found a couple of tranny codes in it. first one was p-0741 which is a TCC system stuck off code and the other was a p-0894 which says tranny slippage. I cleared the codes and took the truck for a ride to go drop off my trailer at a friends house and the tranny shifted fine but after 15 minutes of driving the tranny temp went hot and the information center said the tranny was hot. I stopped to let it cool down and then when I left which was without the trailer the tranny again went hot. Shifting was hard during the whole time. To me it almost seems like the TCC clutch may have let go and started sending pieces of the clutch thru the system and started blocking off the cooler. Does this sound like a logical assumption????
Bummer... Does sound like something was soft insdie and loading a trailer up behind the beast was too much.
    250.3k
    chfkief
    chfkief
  • Who's Online   2 Members, 0 Anonymous, 1,425 Guests (See full list)
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
