Hot Air 1 Side And Cold Air On The Other?
I have a 2005 Tahoe and the drivers side will be blowing out hot air and the passenger side will be blowing cold air even with the airconditioner on. Someone on another site said it might be a temp actuator but wouldn't that control both sides. I was thinking maybe the slide for the temp which I have 2 one for each side is not doing what it is suppose to do? Is that connected to a wire or vacumn to make it work???
No each side has its own actuator. The drivers side is easy, the passenger side is not.
The drivers side is in the 1st page of this link, the passenger side in on page 2.
http://chevroletforum.com/forum/silverado-...lacement-22624/
My 03 silverado had the same problem, it's the actuator. I just took it out, opened it up and cleaned all the grease off the contacts. The casing had grease all over the inside of it. Has been working fine ever since.
    bellssn690
    bellssn690
  • Who's Online   3 Members, 1 Anonymous, 886 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
