Need Under-dash Connector Pn
I'm working on wiring in some power seats. I've got it all figured out except I didn't grab the plugs out of the truck I robbed the seats from. This is the box. IMAG0185.jpg
It's located under the dash to the left of the brake pedal. I'm looking for a connector so I can plug it in and splice off of the connector's wires for my power and ground for my seats. Does anyone happen to have the part numbers for either the two and / or six way connectors?
Thanks for the link! One things I don't understand is how do you wire the connector? Or do they make prewired connectors?
You have to buy the plastic connector piece and then a couple of locking pins (p/n 15317768). You crimp the pins on to your ground and power lead and then push (lock) them in the connector. There is an always hot feed (30A) in the connector slot. I'm sure you can also find the power seat connector piece. MS3Dale might be able to help look that up? Buying the Delphi connector from Mouser is much cheaper than buying the connector from GM from my research.
