2011 Silverado Wheel Tire Combo
For Sale – The tire/wheel package from a 2011 Chevrolet Silverado. The wheels are the Chrome 17” LT wheel complete with center caps. The tires are the new General Motors OEM General Grabber HTS in size 245/70/17. These are a vast improvement over the previous OEM tire. The tire wheel combo has 1,506 miles on them, so they are almost new. They are inflated and factory balanced. The TPMS is not included. These will fit all Silverado and GMC Sierra’s from 1999 up with the six bolt lug pattern. The tire price on the Tire Rack web site is $145.00 each before shipping, installation and balancing. I’m looking to get $500.00 for the set.
Tire Rack Web Site:
http://www.tirerack.com/tires/tires.jsp?ti...do+1500+2wdTire Rack web site.
Looking for a local sale in the Phoenix area.
Lou
I am finding it hard to understand why no one in the Phoenix area wants these. These are basically a new set on tires on a free set of new Chrome wheels. I am open to offers.
Lou
    bellssn690
    bellssn690
  • Who's Online   6 Members, 0 Anonymous, 579 Guests (See full list)
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
