Integrated Trailer Brakes
GG300
I have a 2010 3500 dually -the trailer brakes do not seem to be applying as hard as they should. The integrated brake controller is set to max - is there any other tuning or adjustments that can be made to the brake controller?
will your trailers brakes lock up when you manually apply full trailer brakeing?
If not, it is your trailer.
  • 1 year later...
What did you find was wrong with your brakes. I'm experiencing the same problem.
Thanks Steve
I think my trailer is good, it will lock the wheels when empty, but loaded it does not work as well as it should. I am towing a Case 580D backhoe with it and it is a pretty heavy load
No adjustments available to the trailer brake system other than the gain control.
I meant the trailer brakes specifically.
I was replying to the original posters question about there being any changes available to the trucks trailer brake system.
Oh sorry about that.
No worries.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 832 Guests (See full list)
