Help: Can I Install A Back Up Camera To My Foactory Nav?
ok Guys I ahve an 07 tahoe LTZ ( Didn't come with NAV or backup camera )
I added NAV ( Non DVD) Since they are already in the rear headrest.
Now my wife would like to have a backup camera since we have little kids and things change quick around them.
Do you know if any Camera will plug in and work? Does it have to be factory?
Is my LTZ prewired for the camera? in the tailgagte and behind the stereo if I bought a factory camera?
i didn't want to buy an aftermarket camera and pay someone to pull the Headunit an install it if it wouldn't work?
I guess I can do the install but i am getting lazy and would not want to do the work and find out it was for nothing.
Bump??? Anyone know if a lockpick is needed for sure????
first off you don't really need a lock pick
second in case you don't have the harness for the back up camera you can get it for like $40 on ebay and also a back up camera with night vision for like $17 bucks and you can do the install yourself is really easy, the only thing would be running a wire all the way to the back for the camera but that is easy too
now if the dealer didn't program your h/u for back up camera you are going to have to take your truck to the dealer for programing
but before anything check your h/u and see if you have the option in the menu for turning on and off the back up camera feature, if you do turn it on and put the truck in reverse, if the screen goes black and you see a warning sign that says service back up camera sistem or something like that then your h/u has been programed for back up camera and you will save like $100
let me know if you have any questions
By harness do you mean a factory harness?
I was planning in buying something like this Audiovox Car ACA200W
It was suggested by my local stereo shop.
They thought they could just install it directly to the factory headunit?
darn montyss I wish I had seen this one before I got mine!!!! I like the fact that is wireless and comes with the bezel and a lock, exactly what I was looking for on fleabay for my OEM navigation system, but they didn't know what I was talking about, the only thing is that is kind of pricey
Johnson if you want to save some money and get a decent camera try this http://cgi.ebay.com/Night-Color-Vision-Car...=item2a11dd5ad1
is very similar to the one I have and mine works like a champ!!! and best thing is that if it ever breaks is so cheap to get a new one
and for the harness try this http://cgi.ebay.com/GM-CHEVY-SILVERADO-SIE...=item45fb6af7a6
is exactly the one I got, but you might be able to get it for cheaper maybe from gm parts direct or somewhere else
yep I saw it montyss but the one I have is working like a champ, right now all I need is the new bezel with the lock, which I have seen and is like $50 buck, that and the new harness you sugested for my DL3's I'm just not working that much right now.
johnson did you find out if your nav was programed for back up camera yet?
this rear camera looks interesting and has a Sony camera , wireless backup camera
When I bought my Nav I purchased that harness (so i should be good to go!) I was told it would make the NAV work better when SAT was temp unavail. because of the VSS.
I will check out that camera *(when I had my local Chevy dealer adjust the chime volumes they also turned off the backup screen (so I will have to take it back in.)
thanks for all your help!
Chad
that cam is so cheap is scares me a bit (you get what you pay for sometimes.)
I am looking for one to mount under teh facia above my license plate not on my LP
I will keep you posted in the install!
The one linked to Camera-Source is what I put in my truck (except it was the non-wireless version). Works great. Haven't really tried the night vision yet.
One thing to note, it does NOT come with the lock, just a whole for it. You specify if you want it left open so you can put your own in there or a filler plug glued in it when ordering.
Ernie
that is the camera I got and like I said it works wonders, and at night I can't believe the sharp image, and by the way I got it for only $17.51
about the black screen when in reverse, you can switch that on or off yourself in menu, so if they charge you for turning it on they are going to rip you off, and if they already charged you for turning it off, I feel sorry then
Ernie
thank you for letting us know the deal with the lock, I was under the impression that you specify if you want the lock or not
The screen used to have the "BACKUP" tab but they thought they were doing me a favor by turning off that function. (I am going to see if they will turn it back on at no cost since they turned it off without first asking.)
Got my Tahoe back today and they got the backup screen showing again! (had to hook up a tech II and run through codes and a few VINS etc.) Now just need to get the camera and get it installed!
Showing "service backup camera system" when currently in reverse.(I can turn off the display in reverse if wanted.) I assume the message is there because there is not camera signal?
Well the Camera is installed and works great!iI had it installed it where the factory camera would have been and it works great!!!
here is the camera if anyone wants to know. Paid a bit more for it but supported a local business and it has a lifetime warranty with the shop as does the install work.
http://www.amazon.com/Audiovox-ACA200W-Lic...m/dp/B0016HRCS4
I would be more than happy to take pics if anyone is interested.
    DaleB
    DaleB
  • Who's Online   3 Members, 0 Anonymous, 1,060 Guests (See full list)
    • Yes that's right, it's the upgrade that includes the overload spring and all that stuff.   Someday when I'm empty and going by a scale I'm going to stop in and get some weight readings.   Exactly  you should have the ability to change individual settings, in in Canada so I'm driving with kph but then I'm stuck with kpa when I want psi lol
    • You must have that upgraded gvw package which is only available or at least was in 2025 with the diesel engine for the 3/4 ton and that gave the truck physically the larger 12.0 ring gear rear diff and the 3500 rear spring pack. There is a difference in what the diff housing looks like externally as one tell tale and also your truck should have the upper overload spring pack and the frame pads that the pack goes up against.    The pressure the tpms system kicks the alarm in on a stock setting truck, that is a good question and was just from what I recall but I doubt I made any notes on it as I knew for the rear that it was not at all what I was after regardless either. Being that you have a diesel and if running on stock tires the minimum pressure on an empty truck seems to be around 50 psi from hearing of those that have weighted the front axle but the rear axle is very similar in weight to a gas truck and again a near empty truck on the rear could go down to 35 pounds at minimum. However the weigh scale is the proper way to know for sure as a guide.    As to changing the readings on the dash from metric to the US measuring system, oh yes that is done easily but what I was attempting to explain was that I can't pick and choose items I want to have in US and those I still want in the metric system at the same time as its either all or none. For example lets say you drove into Canada and switched your dash over to metric so your speedometer read in km an hour, well then your reading kilopascals on your tpms readout and your wife looks over and says what the hell is that saying in the tpms screen and you say "darned if I know, I think its Chinese" !
    • This is partly why I decided to have switched over to Amsoil SS as a way of hopefully preventing the buildup of the sludge/carbon on the pistons and clogging of the oil control rings and the carbon that would cause the compression rings to stick in their grooves as well as stay cleaner up top of the heads in the valve train in the first place, an oil that has tested better by third party testing over typical shelf oil and also doing my best to run relatively short OCI. However in saying that I don't think there is any way to easily prove the oil I was using prior allowed for a buildup at the OCI I was doing, nor in the other direction to make claims the Amsoil is keeping everything clean either. There really isn't a window into the engine is there to know anything for certain even if oil samples were taken for example that showed still healthy oil being dropped out of the oil pan other than engine tear downs that extensive and expensive testing of oils does to actually visually see what is really going on inside the engine. I wish there was some easy method of seeing what is going on but I don't happen to be aware of that if there is.
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
