Removing engine head
Hi all,
 I will need to remove the head on my 99 4.8 sierra truck.  I dont want to spend the 1,600 dealership wants on this to fix my intake valve on the 8 cy.
 On the hayes manual. it says to remove the exhaust manfold. then remove valve cover, then remove the springs and etc in the head.  then remove the Head.  Why do you HAVE to remove the internal parts of the head?  I dont understand that.  I will send the head to have the intake valve replaced and fix anything that might be wrong with that 8cl valve systesm.
 So short story long,  WHY do i have to remove those parts off the head before I remove the head?
Thanks!!
I meant removing the springs and etc.
 I dont see why the book tells ya to remove that before removing the head, you HAVE to removing those internal parts of the head.
 So All i do then is just remove the head, then take that to be reparied will all parts still intact?
I would immagine that you have to remove the springs after you removed the head, but you'd have to loosen the rocker arms because you have to release the tension on the pushrods so you can pull the heads up and off without damaging the pushrods.
-Mike
Remove the springs after you've removed the heads.  All you need to do is loosen/remove the rocker arms, pull out the pushrods CMNT recommends replacing them with a chromoly set anyway, but if you do keep them, I like to mark which cylinder and valve they came off of (not necessary but I'm anal retentive) as well as do the same to the rockers once removed.
Then you'll need a new set of headbolts as previously mentioned as they are "torque to yield" bolts that actually stretch when tightened.
They may suggest removing the springs prior to head removal in order to get at head bolts that may be partially blocked (in back), but that's just a guess.
I will back the chromoly pushrod's all 16..and while your in there  you might as well get some fullcrum tipped roller rockers like Harland Sharp 1.6's or something.. If you do check your clearances from the top fo the piston to the valves. and plastic gauge everything.  I've always been partial to ARP fastners.
    btm
    btm
  • Who's Online   3 Members, 0 Anonymous, 1,321 Guests (See full list)
    • Can ask that about a lot of places.   Holiday sells 91 for $1 over 87 octane. BP 93 is 80 cents. Amoco 93 is 80 cents Kwik Trips is $1.20 for 92 or whatever they have and $1 for the 91.   I know that this is not exactly same as what you are saying with the premium to premium debate of those two stations but why is there such a difference. Top Tier this and that, it's all BS. All the fuel comes from the same damn refinery, so give me a break.
    • Why does Mobil Premium cost 90 cents a gallon more than Shell Premium when their regular offerings are but pennies apart?
    • Was all the way down to $3.69 a gallon but then jumped back to $3.99 just because for some reason.   Diesel floats between $4.80's to $5.10ish a gallon. I even saw Diesel #1 for $6.09 today but nobody in there right mind even buys that in the summer.
    • Mine just keeps lagging or getting stuck on the reverse camera. When I turn off the truck, get out, and close the door it will still stay on. It’s very intermittent and I would not be able to duplicate the issue.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
