Looking For Wheel Well Liners
Looking for liners for a GMT-900. Don't feel like paying the $90 something dollars from gmpartsdirect. Saw some sell lately for around $70's. Let me know what you got.
Call your local dealership, they should match gmpartsdirect price. they did for me. If you worried about saving the extra $20 than I dont know what to tell you other than good luck and look for a set of used ones. They are well worth the $90 though, look good and serve a purpose as well
I got a set I took out of my 2008 GMC E. Cab to put in a 2010 that turned out to have them already.
PM me with your location zip code and an offer that includes shipping them. I will see if its worth my trouble to ship them for what you offer.
Never done business with them, just came up in a search for the part # for the liners (19166677)
1stGMCParts--$83.16
GM Parts Direct---$78.30
Prices do not include shipping...if you can get them anywhere for $90 shipped, I'd jump on it. You'll be hard pressed to find them cheaper than that with shipping.
1stGMCParts--$83.16
GM PARTS DIRECT price with their process and handling charge goes up to $98.29....FWIW.
If you think GMparts is high priced shipping. Here is what it would cost to ship the one I have to the OP
UPS Ground 5:00 P.M. Thursday
June 23, 2011 By End of Day,
Tuesday June 28, 2011 163.54 USD *
Days In Transit: 3 Schedule by 4:00 P.M.Thursday
June 23, 2011 Billable Weight:135.0 lbs.
Result estimates calculated by UPS: Thursday, June 23, 2011 2:05 P.M. Eastern Time (USA)
I called local shipping shop and they confirmed, that is the cost. Actual Weight approx. 15 lbs
that's due to the dims of the package...freight companies are screwy
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 832 Guests (See full list)
