Avalanche Vss Wire
I have read so many threads on this but I still can't seem to find the VSS wire for the nav. Any clues where it might be located on a 2011 Avalanche?
and if you are not insterested in that:
then here is a picture of the back of the BCM (under dash drivers side near parking brake) with the wire pointed out:
Slot ID is "H1" on the connector.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,201 Guests (See full list)
