Tow Rating For 08 Sierra Denali
I'm getting conflicting information on the tow rating on my 08 Sierra Denali AWD, 6.2, 6 speed auto. and I can't find any factory charts for it. Anyone have any links?
Trailering & Payload
Curb Weight (lbs.) 5378
Max Payload (lbs.) 1622
GVWR (lbs.) 7000
Max Conventional Trailering, 3.42 Rear Axle (lbs.) 9400
GCWR, 3.42 Rear Axle (lbs.) 15000
Spring & Axle Capacity
Front Gross Axle Weight Rating (lbs.) 3950
Front Spring (lbs.) 3950
Rear Gross Axle Weight Rating (lbs.) 4000
Rear Spring (lbs.) 4000
Right off the GMC website :lol:
GVWR (lbs.) 7000
Thanks, one response I got on another website said 9300lb w/cooling package and 6300lb without! I've never heard of a 'cooling package' in regards to towing. And 3000 lbs is a LOT of difference for ANY kind of 'package'.
BTW, have you towed anything with your truck? I'm looking at towing a 24' enclosed car hauler with a 3500lb car inside.
GVWR (lbs.) 7000
Yeah, I towed a friends camaro on a car dolly. Didn't even know it there till I hit some hills/mountains and even then it wasn't a problem. :P
I thought the 08 was only rated for 8600 or 8700 and in 2009 they increased the rating to 9300.
I remember this because i always thought my 08 was under rated considering the engine/trans/gear combo...
Come to think about it.. your right Matt. It is the 8600 for 2008. Not sure why when the combination is the same :lol:
From truck trends.com
2008 GMC Sierra Denali
Engine 6.2L/403-hp/417-lb-ft OHV 16-valve all-alum V-8
Transmission 6L80 6-speed automatic
Wheelbase, in 143.5
Length x width x height, in 230.2 x 80.0 x 73.7
Curb weight, lb 5400
GVWR, lb 7000
Payload capacity, lb 1600
Max towing capacity, lb 8600
Max cargo capacity, cu ft 53.2
0-60 mph, sec 6.5 (TT est)
Quarter mile, sec @ mph 14.5 @ 93.0 (TT est)
EPA fuel econ, city/hwy, mpg 16/20 (est)
Yeah it's kind of weird. I think it was just under-rated... kind of like an "oops, we rated that truck the same as the 5.3L 4L60E?" and then they corrected it in 2009 and bumped the rating up.
I think the 8.5" 10 bolt is the new limiting factor in the rating; if they gave it the 9.5" 14 bolt like your truck came with that would have been sweet.
    CaptainDad
    CaptainDad
  • Who's Online   1 Member, 0 Anonymous, 465 Guests (See full list)
