Sudden Brake Issues
Well, as some of you may know I bought a new Silverado on Wednesday. 2011 Z71 4x4. On my way to work this morning the brakes had either none (when I didn't press them) or full (when I pressed them). They just locked up and I skidded down the road every time I had to brake. I had several close calls, as you can imagine in an urban area. I called up ON* and they ran a diagnostic but everything came back all clear. After work I started the truck up and did a few test braking sessions in the parking lot and I drove home with no issues. WTH was going on this morning? I'm easy on the brakes but there was no middle area with them. It was like a power switch: on or off. Brakes are the most critical part of a vehicle, if you can't stop the thing then it shouldn't exist. This is unacceptable and I'm not really sure how to go about correcting the issue since it isn't happening any more. Next time I probably won't be so lucky. Does anybody have any ideas about what may be going on?
Take it to the dealer and explain what happened. If they are good,then they will go through and inspect your brake system. It may have to do with some air in the lines, maybe too much oil, who knows, but at least get it checked out and documented. Let us know how it turns out.
    Brendan C
    Brendan C
  • Who's Online   0 Members, 0 Anonymous, 937 Guests (See full list)
