2007 Hd2500 6.0l Oil Usage
saultmanca
Hello
I have an 07 6.0l 2500hd, about 95000k on the motor, and I tow frequently a 7000lb travel trailer. After a long run at highway speeds (65 to 70) at around 3000-3200 rpm, the oil level will be down a little, after one long run the low oil warning actually came on. It was down about half a quart that time. The motor runs well, tows well, and gets about the same mileage my 97 5.7 used to get. Idle is a little rough at times, and it has the vortec's famous piston slap at startup. I know v8s' will sometimes use a little oil on long hard runs, but the mileage on this seems a little low for that right now. I welcome all comments, must be others with a similar issue out there.
thanks
With what your towing compared to the 2000 I had carrying a truck camper at 3500#s. It sounds normal. Although your low oil indicator might be quick to come on.
Mark
Mark
Thanks
It seems that way to me too, it doesn't leak, doesn't burn oil, except for the towing runs at high rpm for extended periods.
My '06 4.8 has 80K on it uses very little oil. I run Mobile 1, change the oil every 8K and it might be down 1/2 qt at oil change. I tow 4K# plus another 800# in the back of the truck and we use the truck exclusively for towing.
I don't drive as fast as you do. I generally keep it at 62mph @ 1600RPM. Because of my 3.23 Gears, I have to climb grades in 2nd @ 3500-3600RPM (62-65mph) to maintain speed. We drove up over 8200' a few weeks ago from Los Angeles, past Mammoth Mountain to Bridgeport (lots of mountain climbing) and used no oil on the whole trip (800 miles).
What gear ratio do you have???? I'm guessing 4:11.
I have 3:73's on mine, with the 6 speed when it has to shift it only bumps another 500 rpm. At highway speeds (65+) at around 3000 rpm it very rarely needs to downshift, even on fairly steep hills. The powerband starts at 3000 and even when towing not much slows it down. My 97 suburban had the 5.7 with 3:42's/3 speed, scary when towing it reved so high on a downshift.
    tararebecca
    tararebecca
  • Who's Online   1 Member, 1 Anonymous, 523 Guests (See full list)
    • I agree, simplicity and reliability matter more as vehicles get more complicated. A V8 work truck option with fewer electronic features and a stronger warranty would definitely appeal to a lot of buyers who use their trucks for real work. Customizing it with trusted outfitters is often the best way to get exactly what you need
    • I’ve heard similar complaints from newer vehicles where the factory “premium” systems don’t always live up to expectations. A good installer should be able to improve the sound without turning it into a bass-heavy setup. I’d look into upgrading the front speakers, adding a quality DSP amplifier, and possibly improving sound deadening first—those changes usually make a much bigger difference than just adding a subwoofer. Hopefully someone local can recommend a reputable installer in the Las Vegas/St. George area.
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
