No Defroster/floor Air
SsgBulldawg
i have had this problem for awhile now and is getting to the point of just selling the truck. my defroster and floor air do not work at all, the recirculate does and the dash vents do as well. also the vents constantly blow, even when the air is turned off. ie when im dricing down the highway or road with the windows down i still get whatever temp the control module is set on. i have a 2006 sierra sle, with the digital climate control. ive tried a new control headunit, and that didnt work. i was told by the chevy dealership that it would be a 100 dollar diagnosis fee but theyd have to R&I the entire dash and that was a 3-5 hour job at a labor rate or 85 and hour on top of the 100. needless to say i left and hadnt gone back. durring the winter i have to go and start my truck a hour early and leave the heater on 90 and if i go into the store i have to leave it running or my windows will ice over. id like to fix it whilst i dont NEED my defroster or floor vents. any help would be much appreciated. thanks all
Jon
  • 1 year later...
Jon, Sorry no one has commented on your post. I just bought a 2000 Tahoe and my dash controller to switch zones (defrost, dash vent, floor heater is not responding to my selection, I suspect thecontroller is bad. I suggest to keep searching posts as that is my plan. Good luck, hope you get heat on the next cold spell (minus here, so far my windshield hasn't had moisture problems yet, defroster would be AWESOME though right now as winter is far from over)
you are now entering the "repair by guessing" area where you can throw parts at the truck and hope and pray it works ,but with there being so many possiblities of the actual problem,you can spend the diag fee easliy by guessing
good luck,....ps ,do you have a scanner that reads HVAC codes??
no code ,we cant help
Getting a code would be a good thing here. If the controller is bad a code should reveal this.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 1,254 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
