Rattling Noise.
Hey all. Quick question. When I fire up my truck (00 Sierra z-71 5.3L) first thing, I have this weird rattling noise from under the hood. (it's not the piston slap/dieseling sound). It goes away when I rev the engine, but when the idle drops down after the rev, you hear it more. When the truck warms up, it seems to go away. I replaced my AC belt and tensioner because it sounded like it was lower and I noticed it bouncing more than I thought it should. The bounce was made better, but I still have that sound. I was thinking maybe the pulley on the water pump?? I will replace my tensioner and serpentine next to be sure, but just wanted to see if anyone out there has had a similar problem. It's not a loud noise, or a clanging noise. I can't really describe it, but more like a vibrating kind of noise. Engine runs at constant temp with no fluxuation on the needle, so I didn't think the water pump was going bad at all. It sounded to me like the sound a pulley would make when the bearings in it start to go. Any ideas before I spend a lot of money and time to yank out the pump? I'm not one who likes replacing things that aren't broken. Thanks!
Valve train?........... Lifters tend to make noise if they loose prime till they are primed back up. My 99 5.3 has done it since I have had it....
Jbo
My guess is the core in one/both cats right off the manifolds let loose. My '00 had that the ones under the cab. It had a rattle when idling, slight increase in throttle/load, and it went away.
Maybe baffle(s) that have broke loose inside the muffler?
