Evap Code And Service Engine Soon Light
Okay, While driving on the highway I experienced a drastic loss of power whenever I attempted to accelerate. Yes something I do on a fairly regular basis while on the highway. Anyway, I took the exit and noticed that while under a light load the engine continued to run fine as with very light acceleration. I also noticed an increased level of sound coming from the fuel pump. (Approximately 1/4 tank of fuel) Did a walk around and for the fun of it I figured I would reset the gas cap. Upon removing it there was a sucking sound. The tank had developed a negative pressure in it that once relieved, the fuel pump sound returned to normal as well as performance. Later the same thing happened off and on with the MIL indicator coming on. I checked the code and it read P0455 - EVAP pressure sensor low press indication. The light reset and the truck functioned just fine for a while. Then the MIL indicator came back on. I checked the gas cap, which I replaced with a new one, only to find the negative pressure again. Right now it's running fine but I want to get to the fix for this so I don't have to deal with it any more. Any ideas guys?
