UPD Intake
This thread is is a continuation of an earlier thread which I haven't posted to since 16OCT02. Here is the link
http://www.gm-trucks.com/cgi-bin....t=12562
Recap:
Started out totally stock. Added UPD intake with K&N filter.
Results:
Lost a little mpg. And, I've come to realize that I also lost a little low end torque.
What I tried to correct losses:
Every combination of OEM parts and UPD kit parts. Filter housings and filters included.
What I currently run and am sticking with:
UPD kit and paper filter instead of K&N. Its the best SOP configuration for my truck. Gas mileage is at about 17mpg average. Torque and throttle response is better than OEM. The low end torque I felt I lost with the high flowing K&N is back and then some (slightly) by going with the paper element. Right now I've got a Purolator paper filter, but may put AC Delco back in.
All the changes I noticed both good and bad have been slight. With all the power these V-8's have, it's difficult to sense changes by SOP.
I don't like to see low end torque loss since most of my driving is city and I rarely get to really open her up. I need all the help I can get with the 4.8L in stop and go traffic, even if it is slight. I would love to go to a dual exhaust, but am worried about loss of low end torque with increased flow. I can't afford to experiment with all the exhaust systems out there to find what suits me best. I traded in a 2000 Furd Ranger on this truck and with the Furd, I had a total of five different exhaust systems on it before I settled on a gibson system. It started to get expensive after awhile. Sorry to ramble on so.
  • 2 months later...
I have been running my UPD with the K&N and drive mainly in town--ave speed is like 20 mph over 5,000 miles.  Getting 12's and when I went on a trip, all Interstate, got 14's.
So, I decided to try the paper filter and stay with the UPD.  I am now getting over 14 in town.  This is only after about 25 miles, mind you,  but I am getting 14's---all city drving.
So.......I am not sure why. It does not make sense at the moment.
Yep, still get best performance with UPD and Purolator paper filter.
I would get best gas mileage with stock filter housing, but I get improved SOP throttle response with the UPD housing. The K&N is long gone.
Which paper filter are you using Doc?
I dicovered that a while back and have tried to pass it on. My truck doesn't like any of the high flow filters and I've tried a few. I too loose low end torque! I'm currently using the stock air box and lid, a Purolator filter and a DJ Motorsports intake tube. The air box has been modified with a ram-air set up which really does help. The only advantage I can see with a K&N filter is that they go forever, 50K between cleaning. I change air filters every 6K, and the $17 does add up. But I really don't care, clean air filters, oil filters and oil are cheap preventative maitenance in my opinion.  :D
Jim
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
