What Size Fuse For A Aftermarket Backup Cam?
magstar67
I bought an OEM mirror with monitor for backup cam from a member here, I have been having trouble getting a camera to work with it. I think I have burned two out already, I didnt use a fuse on either when hooking them up. I have hooked both into the reverse light circuit. THe mirror works because I have tested it using a DVR player on it.
The camera manufacturer has replaced the lastest camera, but their instructions dont say anything about using a fuse, anyone have a suggestion on what size fuse to use for one of these cameras?
Thanks, Jeff
no expert just curious,what camera are you using? Not sure if a fuse is the problem they protect if over drawn on amps and most cameras draw less than 1 maybe 2 amps on the high side. Some cameras are very sensitive to unregulated voltage swings.
My camera is a basic 1" round flush mount ($85) from Rearviewsafety.com, it has the nightvision capability with RCA style output. I have contacted them as well but no response yet.
What are my options then?
I don't think I've never seen more than a two amp fuse on a camera. It's been so long since we've seen a bad camera, especially one that blows fuses, that I'll bet that the harness is bad, not the camera. Have you replaced the harness or connected it without using the harness extension to verify the camera is actually where the problem is?
Walt
www.adcmobile.com
Walt
www.adcmobile.com
I am not using the factory harness, Here is what I did: I tapped into two wires in the a-pillar that are the positive and negative of the video signal feed, I have a RCA plug type cable from the camera to the a-pillar. I cut off the end of the RCA cable there and spliced into the a-pillar wires. The camera has a 6" long RCA cable that connects to my long cable that goes to the pillar. The camera also has a 6" long two wire harness that you hook into the reverse light wires to power the camera. Hope that all makes sense.
I have power to the camera in reverse but nothing on the monitor. If did work briefly the first couple times I put it in reverse to test it but doesn't work anymore. I also hooked the video out line of a VCR to the a-pillar wires to verify the monitor still works and it does work that way.
I haven't hooked the VCR to my RCA cable at the back of the truck though to verify the monitor would work through my long RCA cable, I needed a coupler and didn't have one at the time.
Any more thoughts? Thanks for all the insight guys so far. Jeff
Walt
www.adcmobile.com
I hooked the VCR up to the RCA cable at the back of the truck and it plays video on the mirror monitor so the long RCA cable is good. I am sure the camera has an issue but since I think it is the second one that has gone bad after being hooked up, I am afraid to hook the new one up even with a fuse installed!
Walt
www.adcmobile.com
Maybe a dumb question, but are you SURE you have the power lead to your camera hooked up correctly ie; 12v positive to the positive lead of the camera, ground to ground?
Walt
www.adcmobile.com
No such thing as a dumb question so I double checked and I have the positive of the back up lights to the red wire of the camera
I used an ohm meter across the positive and negative wires of the camera and get no reading so that tells me it is bad. But it did work at first so I did something to burn it out. I just wish I knew what and that the fuse would for sure save the camera this time since I did it to two cameras already
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,260 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
