Battery Isolation
Truckster12
I own a 2007 Classic 2500 HD Silverado, with the factory towing package. I put a 40 amp J-case fuse in the fuse box to enable the 12 volt red feed wire, to my camper battery. Is there a battery isolator allready installed from the factory, so that my camper won`t drain my truck battery when the truck isn`t running? If not, how would I install one? Must I cut the wire loom, to access the red 12 Volt wire, that goes to the female plug, in the truck bumper?
If you have RPO code 8B0 the from the factory the second battery is isolated.
If you have RPO code Z82 then you have the trailer package from the factory.
If you have both codes there should be a fuse in Stud#2 and the postive terminal on the trailer plug should be hot from the factory. If it is not there should be a red wire, blunt cut, bundled under the master cylinder. this will need to be connected to stud 2
There should be no fuse in Stud 1 with 8B0.
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 920 Guests (See full list)
