Performance Issue Tsb
I have a 99 Silverado 5.3 Liter 1/2 4WD. It has had a problem for quite some time where it will run poorly for a few minutes after startup, then seem alright after that. Does anyone know anything about this TSB that I found in another forum, It supposedly fixes the symptoms that I am having.
GM Bulletin No. 01-06-04-006
Date: February, 2001
Subject:
Lean Hesitation, Sag or Stumble on light/moderate Acceleration
Models:
1999 Chevrolet and GMC C/K Pickup Models (Silverado, Sierra)
with 4.8 L, 5.3 L or 6.0 L V8 Engines (VINS V, T, U -RPOs LR4, LM7, LQ4)
Condition
Some customers may comment on the following condition:
A lean hesition, sag or stumble present during light to mederate accelerations.
Usually only present on the first one or two accelerations.
The condition occures when the coolant temp is below -6 Cel and +21 Cel (20 F and 70 F)
Fuels with a high drivability index can also be a contributor.
Cause:
CALIBRATIONS NOT OPTIMIZED FOR VARIOUS OPERATING PARAMETERS.
Correction:
Prom reprogramming
