Lug Nut Help
khancock
I'm trying to replace the OEM lug nuts on my 08 Sierra All Terrain as they are starting to look like hell. I decided to order McGard 84620 as a few people on the site mentioned using them when I did a search and their site states they are compatible with OEM wheels. So I go to put them on and they are obviously wrong. I'm wondering if anyone has had the same problem or has any idea if I ended up with the wrong part or what the hell happened?
New (see how skinny it is)
I have been running those lug nuts for a year now no problem. They look small when compared to a 22mm but the taper seats properly to the wheel.
Well they are on their way back to amazon.com as I didn't like the look of them. Hopefully the other's mentioned fit better. I'll report back.
Also, I wonder if there is any difference as I have the 18" all terrain style wheel and you don't?
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,163 Guests (See full list)
