Heater Issues
my 2003 2500hd has the manual dual zone climate control here is my issue when the selector is on vent air comes out of the defrost when it is on defrost it comes out the vents also drivers side never gets as hot as the passenger side this problem started after jump starting another car (cables were properly connected) i have read that bcm may control the climate control iif so how can i reset the bcm if possible? or any other suggestions
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,179 Guests (See full list)
