Pacesetter Header Install
hey guys i recently installed a set of pacesetter LT's with a flowmaster 40 dumped at the cab. install went quick, minus 3 bolts breaking in the heads :-/ but all in all a 250 buck investment, i noticed alot better response in the throttle esp at highway speeds, and i did pick up 2MPG's steady sofar (about a month or so since install) all the mods sofar ive done
CAI
Bullydog Tuner
Pacesetter LT's
flowmaster 40 (single not dual)
Plat Plugs
accel wires
any other mods i can do without cam/intake? also ive had a problem with the starter and might have to get a new fly wheel, any input on a stall while the trans is out? im plannign a 160 ther. ive also heard for cutting a hole in the MAI to allow more flow? also was thinking of a TB spacer.... i figure for 20 bucks a TB spacer couldnt hurt. i also have read about some sort of emission crap under the engine cover? well thanks for any imput!
Get a black bear tune,Then youll really get the most from your mods,2600 stall should perfect,might as well throw a shift kit in the trans.
Are those the quick trip pacesetters for off road use? Though I wouldn't use them for off road lol, they seem to be good for the price.
i dont know if theyre quick trip, but they are the LTs for "offroad only" lol but i live in arkansas and we dont have a vehicle inspection whatsoever so i can run them. the guy had them on his 06' and had bungs installed for the two front O2 sensors. i just took the read off and deeal with the check engine light. yeah i looked on the site and they were close to 500 but i picked them up for about 250 total, i drove the womans car (38mpgs hwy vs my then 13) 200 for the the headers and y pipe. and installed everything myself. and it sounds mean as hell lol. only deal is i wish i would have been able to wrap them before i installed them cause the underhood temp is alot hotter. i did pick up after my install and turning my programmer to performance alot better response and mpgs
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,058 Guests (See full list)
