Rear Axle Removal
Need to pull the rear axles on 2003 silverado 1500 .I took out the locking pin but there is a aluminum bracket that holds the gears in place in the way of pushing axle in to remove c clips . Any advice .
Pull 8 mill bolt out rotate chunk remove round pin and push axles in and remove c clips let me know if you have other questions on the axle
Job complete , new backing plates and seals.That aluminum block in center just needed a little wiggle with needle nose pliers then the axles pushed right in. Thanks for the tips.
  • 3 years later...
Did you leave the large main pin partially in or did you remove it completely. I have the same problem right now and I have tried moving the aluminum thrust block with a needlenose but no luck.
