Rear Speaker Rattle Question
i replaced the rear speakers with 6 1/2 after market ones, and now they rattle, the speakers are not rattling its the paneling, is there any way to help with this? something i can put in the doors to stop this rattle noise?
Tons of dynamat and a prayer. It depends how how much rattling we are talking. The doors like most of the rest of the truck are made of thin sheet steel so vibrations are going to result.
Get a few sheets of dynamat and line ever sq inch that is free; just be careful not to put it in places that might interfere with any of its its operations. Not just the outside where the speaker is mounted but also the inside steel as well. The more the better. Some people like to even add more then one layer of the stuff.
See if that helps. Truely the best way would be to filter the lower frequencies (with a crossover or inline filters) and use a sub for lows but I dont know your setup. If you are not planning to do a sub see about getting filters.
Ernie
Ernie
i have 2 10s in the custom box for the silverado, i have 4 infiniety speakers powered by a 4 channel amp, then the subs are powered by a mono amp, the only time they rattle is when the music is turned up and its like the high frequency makes the panels rattle
Ok, so you have a good setup up then. Does the 4 ch amp have a crossover built in? If so, you can experiment with it to see if it helps with the rattles.
You can also download some test tones, burn it to a CD, and run through the frequencies to see which triggers the rattles. That will at least give you a definitive answer for what is causing it:
http://ampguts.com/index.php?pageid=audio_downloads
So did you use dynamatt during your install?
Ernie
Dynamat help a lot in my truck and made it sound better. The panels still rattle some at the top and the only thing I have found was to wedge them with something.
I have some pics in my garage of the dynomat. I cut it up and put in all around the door. I used a half of sheet to go behind the speakers to make it sound better.
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 449 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
