Aftermarket Muffler?
okay so i have done abit of searching on here in regards to aftermarket muffler... have found abit of info here and there but hard seeing alot of it is all over the place or just alot of stuff in the wrong sections....
so basically i have a 2011 sierra ext cab 4.8l now im looking for a little more low end and have been told and researched exhaust can give you a gain...
not looking to go crazy with exhaust and more or less looking to go with a aftermarket muffler.... anyone have any ideas if theres any low end gains in doing just muffler?
just looking to swap stock and replaced with aftermarket
by the looks of it, its 3" in/out....
any info greatly appreciated
thanks
When I was doing my research for a muffler a lot of people that I have talked to and on here said that you won't get any performace out of it on a gas engine, you only get a sound. When I finally bought my corsa sport exhaust, I did see improvements though. The improvements are't a lot but I could tell the difference. One of my friends put a borla muffler on is 09 and he said the same thing but it didn't shut up when he was towing anything, it sounds good though. When I drove it he didn't have the same increase that I did though and I think it was bc I went with bigger pipes and he just changed the muffler. It cost him 290 with it being welded to the pipes. At the end of the day I would make your decision on which muffler you like the sound of the best and hopefully you will see the improvements that you want. But don't expect anything to high and whatever you get will be happy with bc your standards are lower than what you get and maybe that's why I feel like I got more out of it then he did.
Ps I don't know if they changed the pipe size but I have a 09 and stock pipes were 2.5" and when I got the cat back they are 3" pipes. It was a big difference when I saw two next to each other.
Hopefully I helped and good luck.
Low end power is mostly torque not horsepower. Backpressure increase torque.
So you will have more low end power with your stock exhaust.
thanks for the info... i took a tape measure not that it will be that accurate when measuring the pipe itself however i was almost positive it was 3 inch... i have seen many other sierras and have looked at for instance the tail pipe just behind back wheel and looks smaller then whats on my truck... which is why i would think its 3 inch, ill have to dig out caliper to verify that...
just a little extra in the low end would be nice
and also all depending on budget will determine my hp gains, but a nice sound is worth it aswell
i have read that flowmaster seems to kill some of the power, which is what i was looking at.. and read magnaflow have better gains just not the same sound aswell as lasts longer..
so i guess will be hit or miss for me... have seem many around here stock id imagine with the GM exhaust system on it because of the sound, wonder what the difference of the stock exhaust is to the GM step up exhaust
so then with that said in order to get more torque in low end id need to tune?
deff has good torque in 4 low lol however its built that way... pulled out some big swing set footing this weekend with it...
but in terms of taking off from a set of lights the real power does hit till about 2500-3000
i had a rental which had the 5.3 in it 6 spd which had alot more low end mind you thats expected with having the extra gears...
The six speed has a 4.02 first gear while the four speed has 3.06
So the six speed has a stout first gear.
Do you have 3.73 in the back? Are you talking about power when you lay on the gas or slow pulling power?
i had 3.73 when i had my colorado and it went like as at our of hell
however this one here does not have the 3.73 whcih i know will make a difference i just checked and it has 3.23
when i lay on gas from a stop its sluggish
when im at about 40km and lay on it , it goes... while moving WOT it goes however from stand still not so quick...
lots of pulling power as i challenged that this weekend
Get a tune and forget about the exhaust.
Look up "4 second delay" sounds like one of your problems.
in terms of a tune, what would be a recommended tuner/ programmer
worth it to get done at shop
and pro`s and cons
also id imagine voids warranty...
thanks for all the info so far!
i must add aswell i have larger tires then other sierra/silverados i have seen which i know will make abit of a difference
from dealer 265/70/17
most ive seen are 235`s
and pro`s and cons
You have canned tunes like superchip, edge or Diablo. These help some but not as good as a custom tune. Diablo is my favorite and they are a site sponsor. They are the best gas burner handheld I know of. They allow you to customize your tune to run better. However they never offered TCM support so I never bought one. I owned a Edge for a year and will never buy one again.
Custom tunes are the best and you can get any shop with a dyno to do it. Everyone on the site including myself recommends Blackbear because he is very friendly and knows what he is doing. He is also a site sponsor.
Any tune will void your warranty. You just have to remove the tune before going to the dealer. The dealer does not typically search for tunes on gas trucks. They tend to focus on diesels and sports cars.
If you get a custom tune you will need to buy the autocal to remove your tune. Or you will need to buy an extra ECM and TCM. I'm guessing you have a 4.8L with 4speed trans?
interesting info...
i do have the 4.8l, kind of oppted that because the 5.3 didnt seem much different and the one i drove seemed to up shift and down shift alot...
eventually move up to the 2500 but that will be a long time yet, and probably will be something better then as i just found an article on the new colorado and GM`s direction towards the GM version of eco boost
and pro`s and cons
i see you have the corvette servo, whats that like? pros cons
gains?
cost involved
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 281 Guests (See full list)
