Looking For A 2.5" Leveling Kit. Recommendations?
I have a 2" RC kit installed and the rear is still high by about 3/4". These reg cab short boxes sit kinda high. Anyone know of a company to just get a spacer for another 1/2"? (My RC kit is an older kit that has 3 separate spacers stacked on top of each other that mount under the strut.)
used a NCD 2.5" leveling kit on mine, with 3" rear block, gives a nice rake i think. either way im a fan of my NCD kit, personally machined out of aluminumn block right here in the great USA, couldn't ask for more!
Total Performance also makes a kit that will net 3" of lift from what ive seen
    President Roberto
    President Roberto
  • Who's Online   0 Members, 0 Anonymous, 218 Guests (See full list)
