Line of fire bar for my Yuke Denali
I purchased a pacer 60" line of fire flexible bar. This is my 2nd set and the first set did not stick on well on the lip of the rear bumper cover. The reason is that the 3m tape does not adhere well to plastic. Are there recommended adhesives out there that work well adhering plastic to plastic? My other option is to fabricate a few sheet metal brackets painted in black and use the 3m tape that it comes with to adhere it.
Any recommendations?
You should be able to get 3m tape to stick. I've never had an issue. Before sticking it, make sure you use alcohol to clean the area which seems to help alot.
