Throttle Position Sensor
dannyboy20
Driving my truck yesterday the message "engine power reduced" flashed on the dash. At that point I couldn't exceed 30MPH. The engine was by no means overheating as the owner manual states. I had the code read and it came up as the "Throttle Position Sensor". Has this happened to anyone else and if soe is this an easy repair.
no mention as what year of truck you have
and the repair is done after the diagnoses is done for the trouble code and what repair is indicated from the diag.
its not just the TPS that can fail
this sounds like what happened to my 03 5.3. it was the gas pedal position sensor just didnt say hi fast enuff cause after i had a friend clear the code it has yet to come back... just check the code go from there. sometimes the GM check engine light likes to say hi for no reason.. but i had the same situation, no power and took forever to hit 30 mph i think it maxed out at like 45 ...
    President Roberto
    President Roberto
  • Who's Online   0 Members, 0 Anonymous, 222 Guests (See full list)
