transfer case clutch pack
i own a 1999 silverado 1500. with all 4 wheels off the ground, and in 4wd, all 4 turn. with the front wheels on the ground and the rears still off the ground, the drive shaft to the front wheels will not spin. 240k on this vehicle, was told it may be the clutch pack in the transfer case, the case switches between 2hi, 4 lo and 4 hi normally. last transfer case i had apart was my 88 blazer which was different than how this one works, was wondering if this sounds like the clutch pack in the transfer case, and what is involved once it's removed, thanks in advance, ed
yes, googled the issue, common problem seems to be the clutch pack in the transfer case, just had the front diff apart this weekend, pulled the housing apart on the pass side, pulled everything apart to check it, changed outer seals, fluid, everthing in the front diff seems to be working properly.
    appletrav
    appletrav
  • Who's Online   0 Members, 1 Anonymous, 499 Guests (See full list)
