Do I really need a Big 3 and a better battery?
I'm finishing up my stereo install in the next two weeks, the final components are shipping. I'm wondering if I really need to do the Big 3 with 0 gauge power wire and upgrade the battery to an Optima yellow top?
2009 Silverado Ext Cab LT
Stock HU with JL Audio Cleansweep
JL Audio HD 700/5 Amp (700 watt)
4 Infinity Kappa 6.5 speakers (coaxial out back, component set up front)
Alumapro CAP 5 V2
4 gauge power wire
Monster Cable 402 XLN 16awg speaker wire
Digital Designs 10 insch sub (this won't go in until later, but it handles 300W RMS at 4 ohms)
So, I'm pretty sure the stock alternator on this truck is 145 amp. Stock AC Delco battery is 615 CCA, 70 Amp hr.
Measuring the stock pos and negative leads off the battery with calipers it's 3/8", which is about 4 awg right?
So, for running one 5 channel amp and using a 5 farad cap, you think a Big 3 upgrade and Optima Battery would be overkill?
It couldn't hurt and would certainly be a recommended upgrade; however, everything might be fine without the Big 3. The truck isn't very old and the existing grounds and factory wires may be perfectly adequate for your system. Give it a try and upgrade if you have problems.
Thanks. I think I'll install the system and monitor the voltage and see how it plays out. I might be just fine.
Looking at the cost of the Optima Yellow Top plus the amount of 1/0 AWG I would need it might $400 I don't really need to spend.
That Cap is not going to do you any good ...
Capacitors are a gimmick, why add a cap that will be useless and inaffective (from personal experience and testing). A capacitor doesn't store enough power to sustain an amplifier trying to reproduce a heavy bass line, and once the capacitors charge is depleted the alt has to work even harder to recharge the capacitor and still supply the amplifier with the current it needs.
Capacitors, by nature work perfectly like they are supposed to, attempting to equalize the DC voltage ripples caused by your amplifier(s), BUT they are far too small, one farad, is an incredibly inadequate amount of power. It will take a 180,000 farad capacitor to store the same amount of power as your average car battery, again that isn't your typical, 100+ amp hour audio batteries we are all accustomed to, that is a basic 50 amp hour car battery.
    Matt Parker
    Matt Parker
  • Who's Online   3 Members, 0 Anonymous, 878 Guests (See full list)
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
