Best tie downs
I am looking for recommendations on the best stake-hole  mounted tie downs.
I am thinking that the pop ups would be nice - but do fear that there will come a time when they will refuse to pop up.
Really do not want 'junk'  - I once had some that were OK but the anchor piece (was exactly like a standard heavy duty household wall anchor)  rusted out in less that 3 years.  I figure Stainless steel would be key & am figuring on having to pay a premium price.
I think I have seen some from Steelhorse(?) and some from "Bully"    -any comments, additions , suggestions?
Thanks
I chose PUTCO for these main points:
1-Stainless construction.
2-1000 pound capacity each.
3-pop-up design
4-Lifetime Guarantee.
Click for Pics
PUTCO Stanless Steel Tie Down--Black Chrome
Putco Pop Up-Tie Downs The post "POPS" up with a patent pending cam system that is activated by "pushing" in on the post for the up position and back down on the post for the hideaway position. Each position is locked into place. --One SKU fits all full size applications with stake bed pocket holes. --Zinc die cast part with 3mm OEM quality chrome plating. --Tie-down strength rated at 1000 lbs per tie-down kit. --The easiest to install, the strongest tie-down strength, and the highest quality mounting system available. Sold in Pairs in a retail "clamshell". --NO DRILL installation utilizes Putco's patented rubber expander technology. Putco's New Pop Up-Tie downs are NEW for 2003 and available in mirror finish or black. Sold in pairs (2 per set). This product works with bed caps with stake pockets or without bed caps. A no-drill installation. The tie-downs simply mount into your trucks stake pockets. The post "pops" up with a cam system that is activated by "pushing" in on the post for the up position and back down on the post for the hideaway down position. 3mm OEM quality chrome plating. Tie-down strength rated at 1000lbs per tie-down kit. These tie downs are compatible with the Access & Literider Covers. Universal Fit. One size fits all.
Many choices are out there. Check them all out and get what best suits your needs. Good Luck.
