3500 express traction control light
Hello all. I am new here and am trying to assist my father with his 2007 chevy express 3500. It's a 14-passenger, so long wheel base, I presume. V8 gasoline.
It started a few weeks ago. It was intermittent, now this is always happening. When coming to a complete stop. When he starts going again, the traction control lamp starts flashing for 5 seconds we he goes over 5 miles an hour. Then it goes out. This will happen every time, unless you slow down to more than ~ 5 miles an hour. Then no flashing stabilitrak light. Also I hear a clicking like noise from what I think is the front drivers side wheel.
This was happening before we had the rear brakes serviced. It made no difference.
If it helps, the van has over 75,000 miles.
Thanks for any assistance.
Sent from my VS910 4G using Tapatalk
could be anything and so the only thing you can do is take it to get it scanned and diag'd,,,and reply what the tech said ,,,
internet cant help u on this one untill the diag been done ,,, sorry
Would that have to be a dealer scan? Or will an off - the -shelf ODB II reader work? The check engine light is not on. And I belive it passes the prove out test.
scanning it is only a small part,the diag is a process to find the root cause,
any desent shop can do it but the pros are the dealer techs ,there scanners are awesome,but i am BIASED !!! lol
  • 3 weeks later...
Resolved. It was the passenger side front hub /bearing assembly. The trac sensor is sealed. It was expensive at the shop we went to. The mechanic said that when that happens the system trac control is resetting and not usable at that moment.
    CaptainDad
    CaptainDad
  • Who's Online   4 Members, 0 Anonymous, 484 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
