Before I screw it up....
Ok, I'm going to ask this before I do anything instead of asking how to fix it later.
I had a gps mounted to the top of my dash.  I didn't want to use screws so I used velcro tabs.  I thought it would be a great idea except that the sun beats through the windshield and the adhesive came loose.  So now the tabs are off but some of the adhesive is still there.
Looking for a way to clean the adhesive without damaging the dash.
Any Ideas? ???
take a damp cloth and let it sit on there for a while (in the shade) so that the adhesive is nice and wet and then see if you can rub it off w/ your thumb.
If that doesn't work use an adhesive remover, but try it first on another dash piece that is out of sight to check for discoloring.
Be careful of what you use on there, the dash seems to be sensative to harsh cleaners and stuff. I would do the damp cloth deal or try taking a hair dryer and heat the sticky residue then try to scrape it off. Also try some WD40 or something, I would much rather use something thats not going to harm the dash and use a little more elbow grease.
I've had good luck removing tar and sticky stuff with a product called oops!  It also works well for removing bug guts off of the grille and bumper :D
Acetone:
It's about $2 a quart at your hardware store.  Or for $2 you can buy 6 ounces of nail polish remover (which is the same thing with sweet smellum added to it).
Acetone should not discolor your dash or anything...and I GARONTEE it will cut any adhesive.
If you ever plan to stripe your truck with stick on striping...take a rag and dip the end in the acetone and sorta draw a line where you are going to place your sticker.
The acetone will remove the waxes from the finish and allow the stickers to stick to the paint better.  IF you do this first...THEN you will not have your stripes peeling off later!
    Brendan C
    Brendan C
  • Who's Online   3 Members, 1 Anonymous, 1,183 Guests (See full list)
