will the 2011 oem 20" wheels fit a 1995 K1500 ?
neto1978
If I am not mistaken the k1500 in 95 was a 5 bolt and the 2011 is a 6 bolt wheel. The k2500 is a 6 bolt and the 2011 wheels will fit as far as I know.
To be on the GMT-400 specific here, only 2wd GMT-400 1500 trucks were 5 lug. 4x4 were 6 lug and it is the same bolt pattern used today. As far as new wheels on old trucks, check some of the GMT-400 specifc forums out there. They appear to just bolt right up. I've seen them with the 18" Z71 wheels, and the 17" aluminums, and I think with 20's. The 6 x 139.7mm (6 x 5.5") bolt pattern dates to 1967 if I recall. Per this sites chart (http://www.vehicle-bolt-pattern.com/chevy-lug-reference-guide.html), 88-current have what they call medium offset.
Check the 3rd post down here: http://www.gmt400.co...ull=1#post97733
with the z71 wheels: http://www.gmt400.co...pdated-pictures
Post 26 in this thread: http://www.gmt400.co...ull=1#post34916
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 713 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
