NNBS Steel Wheel
viper919
check out craigs list and post a want to buy add, i got a set of 17 in escalade wheels for $140
dealers were looking for 100 per steel or so for take offs.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
