Rear Wheels Slipping??
brandonjbb
PLEASE HELP.
I currently had my axle replaced due to icy weather when I lost control and rear hit perpendicular with curb. They replaced my axle. Here is the problem now. When I go over a bump or make a turn. It feels like my transmission is slipping. The only time it does it is either when I turn or go over bump. It shouldn't be my transmission, my truck is new and I drive like a grandpa. I was thinking it might have something to do with the anti brake system letting the rear wheels slip for some reason. Please Help! Thanks
Brandon
2008 GMC Vortec MAX
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 501 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
