Mileage
What kind of mileage improvements have you seen with an exaust and/or air intake change?
Also, any difference in mileage with larger tires?
Mike
I reprogrammed my computer with a Superchip..put Duals, K&N Filter Charger II and 285's and I get right around 12-13mpg out of the 6.0L motor
Bigger tires will raise the truck so more wind resistance = less mpg's.  It's probably fractional by it is still true.  Keep in mind if you don't recalibrate your speedo/odometer, you won't be recording the actual number of miles traveled per tank.  You'll have to figure in the variables of the larger tires and take that into acount when you fill up the tank and check your mpg's.  You will record fewer miles on your odometer than what you actually traveled.  A K&N or UPD should add about 1/2 mpg's under best curcimstances along with some increased performance.  I don't know about the exhaust because I'm still running the stocker....
    FiLo
    FiLo
  • Who's Online   6 Members, 0 Anonymous, 694 Guests (See full list)
